Stock lsv in a gsr build horsepower and torque
Just wanted to know what number ill get. I already have all the parts to assemble just waitin to get my crank and block back from machine shop.
Gsr block
Honed
Gsr girdle
Oil squirters ( might have to plug up but ill check when I get it assembled )
Ls crank
Ls rods w/ arp rod bolts
Usdm type r pistons
Arp head studs
Gsr head cylinder stock
Stock manni
Resurface bottom head
Just super tech dual valve springs and retainers
P72 ecu with base map
Everything else stock but I will add bolt on later just want an idea of a number on stock.
Gsr block
Honed
Gsr girdle
Ls crank
Usdm type r pistons
Arp head studs
Stock manni
Re: Stock lsv in a gsr build horsepower and torque
id guess similar horespower to stock gsr except with broader torque curve. a set of type r cams in that thing would really wake it up
How much are type r cams? I know I did some search on skunk2 and Brian crower and priced pretty high but gain a lot of horsepower
eg4life1202
09-20-2006 11:22 PM
Combustion Contraption
17
04-13-2004 07:06 PM
