ecu help
Old Nov 30, 2012 | 03:22 PM
justin11's Avatar
Default ecu help
Ok let me explain the build, I have a 97 honda civic and I am currently working on a ls/vtec swap and now that I am almost done idk if I should get a obd2 gsr ecu or swap over to obd1. I have never done a obd2-obd1 swap so I dont know how easy it is. Any help would be nice please and thank you.
Old May 11, 2013 | 02:56 PM
grumblemarc's Avatar
The Grumpiest
Default Re: ecu help
Did you read any parts of this thread? Try t do some footwork.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old May 13, 2013 | 06:09 AM
justin11's Avatar
Thank you very much I have read that and I am using it as a guide I just didn't get to the part about the ecu
Old May 13, 2013 | 07:43 AM
The Grumpiest
What part aren't you getting? Mind not being so vague?
Old May 13, 2013 | 10:18 AM
nealnanoHX's Avatar
Best way to do it to get a P28 ECU, Hondata and a OBD2-OBD1 jumper harness, very easy. Then have it tuned. This way all variables on the head, block, sensors ect all all covered. If you use a GSR ECU it is best to use the GSR head and intake and you will need to wire a knock sensor along with all the other wiring needed for Vtec and the B series swap.
Old May 20, 2013 | 03:40 AM
justin11's Avatar
I didn't get to that part yet thanks though I just ordered the obd2-obd1 jumper harness. Thanks for you're help
justin11
May 11, 2013 02:18 PM
Agent_EM1
11
Jan 27, 2009 02:24 PM
cramers coupe
May 29, 2005 05:50 PM
jetpilot
Dec 8, 2004 01:29 AM
mrlegoman
Aug 9, 2002 08:44 PM
