Ej2 b18c-r swap check egine light
I have done the swap and fired it up. Im using a rywire conversion harness. Car is a 93 civic dx. Im using the jdm p72 ecu. It is throwing code 9, 14, and 20.
Re: Ej2 b18c-r swap check egine light
9 is no1 cylinder position, 14 is electronic air control, and 20 is electronic load detector. If some of these are sensors where are they and if not how to fix them.
Been a long time since I have been on here. Oh and I found the problem. One of the rywire plug wire on the dizzy connector was pushing out when I was trying to plug it in. Been running like a champ. Routine oil changes and and a lot of races.
Reset the ECU then drive for a few minutes, see what codes come back. The distributor pin was probably for the CYP sensor code. The IACV code is pretty obvious, if it was unplugged at any point it would pop up too. The ELD code isn't a deal-breaker but indicates a bad sensor or wiring.
NotPhilTran
11
06-01-2005 08:25 PM
