B18 swap in a 88 crx si..help!!!!
I have some rookie questions that I need answers to..first off..I have a b series shift linkage..how do I put in on and get it all connected?!?..also I have the original clutch cable that came in my crx..I've been told that I can use it?!?..is that true?..if so can anyone tell me how to connect it??..any help will be really appreciated..thanks!!
Re: B18 swap in a 88 crx si..help!!!!
My shift linkage is off the car and motor..how do I put in on and get it all workin with my shifter?..and can I use my crx si clutch cable with the b series motor?..and if so..how do I connect it to my tranny?
no your clutch that came with your crx is a D, you cannot use it. wont fit B, also your linkage would need to be cut/weld if it's from integra. not a direct bolt on.
Ok..I kinda figured my clutch cable wouldnt work..and no matter what I would have to cut and weld my shift linkage?..there's no way around that?
I have spare JDM Crx linkage, as well as Hasport linkages, both will work depending on how close you are. Also, I used my stock clutch cable with no issues at all. Maybe I've done something wrong but then again it drives?
ADAMnQuickRDX
03-22-2009 11:39 AM
supracrx
Northern California (Sales)
12-16-2005 11:32 PM
silverbullet02
06-07-2003 05:37 PM
al0ne
05-23-2003 06:15 PM
