Emmisions Help
Old Dec 16, 2012 | 09:35 AM
UndisputedH22a's Avatar
Icon3 Emmisions Help
I have an Itr swap in my 98 ek n of course gotta go through wonderful emmisions here in Md and im on a p30 with basemap and im wondering if i plug an obd2 p72 in would that car pass with that ecu if not throwing any codes?
Old Dec 16, 2012 | 09:50 AM
HKSkiD714's Avatar
Default Re: Emmisions Help
Should be on back on point with a p73 98spec
Old Dec 17, 2012 | 11:37 AM
Si_chRis's Avatar
If your swap is USDM, a P73-A03 ECU (from a 1998 USDM ITR) is what you need for emissions. A P72 from a GSR will work but, there may be extra sensors on a GSR engine that an ITR engine does not have, this will give you a CEL.
If your swap is JDM, you need a USDM VTEC solenoid, CKF sensor (located on the oil pump), and you need the EVAP purge solenoid hooked up.
Also, you can do the CKF bypass trick (google it) instead of swapping in a oil pump with a CKF sensor.
Old Feb 21, 2013 | 03:55 PM
Thanks for that info i appreciate it that's good to know for sure about the jdm motor ill look into this i just git a 4month extension on emissions
CreeWorks
16
Jun 19, 2012 06:08 PM
EKwhiteboy
13
Apr 23, 2011 09:14 PM
gsr-t9303
Apr 22, 2011 10:23 PM
Hurleystrcr9621
Dec 7, 2009 07:40 AM
96BlackHB
Jan 13, 2004 05:53 PM
