H2B IACV 3 wire to 2 wire HELP !!!!
this is the only thing thats left so al have no engine management lights on my h2b swap
im using the h22a7 accord type r engine (2001) on my 96spec integra type r
and im using a obd1 ecu
now the h22a7 inlet manifold has a 3 wire idle control valve ( IACV )
and the wiring loom for the engine only has 2 wires.
now ive tried all the different combanations of wiring i it in, but the engine light is still on, one method worked and the idle stayed lower but it didnt seem right and then later the engine light came back on again.
what am i doing wrong, have i missed something or do i have to use a obd1 2 wire idle control valve from an older h22 engine??
Re: H2B IACV 3 wire to 2 wire HELP !!!!
I do not believe the 3 wire IACV can be controlled by an OBD1 ecu. Also the EK civic 3 wire IACV might bolt up but i am not sure.
So using and OBD1 ecu, yes that is the only way.
xKING239x
03-29-2013 10:03 AM
