93 honda dx B18C-r swap
I have a 93 civic dx manual. I have a 98+ B18C-r full swap from hmotors. I also bought new mounts and OBD1 to OBD2 wiring harness and hmotors swap my axel shafts to the USDM shafts. I was wondering about vacum lines, gas lines, raditor hose, and other stuff to make it work and do it the right way. thanks
Re: 93 honda dx B18C-r swap
Thanks man, been doing that but nobdy every list the small stuff, or the argue back and forth and i cant tell who is right. I just want to know about vacum lines gas lines, Throttle brackets, things i got to change over to make it work, little stuff like that. From someone who has done it. I got a long break coming up and i dont want to pull the motor out of my car and be stuck with it out it my daily driver. just trying to get everything prepared.
Ridin Dirty in Cali
[QUOT=bad23591;48127270]Thanks man, been doing that but nobdy every list the small stuff, or the argue back and forth and i cant tell who is right. I just want to know about vacum lines gas lines, Throttle brackets, things i got to change over to make it work, little stuff like that. From someone who has done it. I got a long break coming up and i dont want to pull the motor out of my car and be stuck with it out it my daily driver. just trying to get everything prepared.[/QUOTE]
Before you start do your homework.
Visit the hybrid forum and read read read.
There are plenty B18A B and C swap threads.
The sections you need to pay attention as the ones you listed are in there.
Also, if you have access to a Integra go pop the hood and take some pics.
You'll have your blueprints.
its not really rocket science if you model everything off the integra engine bay.
Ight. Thanks dude. And i saw that the 93 the coupe is a ej2. Will the motor mounts bolt right up like the eg. I have new hasport mounts im using.
bruvaman
07-16-2002 02:05 PM
