F20B with lsd trans bolt up to h22a with non lsd mounts in an ek?
Just as the title states guys, i got a 2000 ek hatch with a blown Jdm h22a. Iv done a ton of searching and cant find any definite answers. I need to know if I buy an F20B with its factory lsd tranny, if it will bolt into my current mounts for my h22 with non lsd tranny. I also need to know if my shifter cables will work too? Im pretty sure they will but i just need some solid answers.
Re: F20B with lsd trans bolt up to h22a with non lsd mounts in an ek?
Yes F20B is the same as the H22A however you will need to swap the driver side engine bracket that bolts to the motor on the driver side for the H22A one. F20B is Accord Motor has shorter stud distance then H22A so simply swaping the engine bracket will solve the issue. However will need to take crank pulley off, timing belt plastic and timing belt if you can't wedge it in there.
90-93 Accord Shifter Cables and Shifter
94-97 Accord Shifter Cables and Shifter
92+ Prelude Shifter Cables and Shifter
Dont mix match cables and shifters between the 2. Prelude shifter has more aftermarket for it, short shifters etc.
Thanks for the reply. One other question will my axels work as well? or will i need custom F20B ones? Keeping in mind i already have custom axels for my current h22a swap...
Yes axles and midshaft you currently have will swap over to the F20B. F20B is just like most F/H share same castings transmission and engine wise. Spacing diameters etc.
