Which intermedaite shaft for my swap??
Which intermedaite shaft do i need for a ls/vtec swap into a 98 civic dx coupe?
Im using a b18a
Thanks
-BRian
Im using a b18a
Thanks
-BRian
Re: Which intermedaite shaft for my swap?? (vtec69)
you will either use an LS or GSR intermediate shaft. Both will work, however, if you use the LS shaft make sure that you order LS axles, not GSR. If you use GSR shaft, then order GSR axles. The ends are different on the two. GSR i.s. has a male end, and the LS i.s has a female end. I just took off an LS i.s on my car and replaced it with a GSR is....long story, but trust me, the length of the two are the same.
If you have the b18a intermediate shaft, then get a 90-93 integra axle. Basically, you need to use the axle that goes with the intermediate shaft and you'll be fine. You can use the 94-01 integra intermediate shaft and then you need to use the 94-01 integra axle.
rewerbcrx
07-27-2007 06:05 AM
