Osaka H22a Engine
Old Nov 4, 2002 | 09:07 AM
ransack's Avatar
Default Osaka H22a Engine
Over this winter I wanted to save up and finally swap my engine. Its not that im low on cash, I just cant get alot quick. osakajdmmotors.com has h22a swaps for 1850. If I purchased that swap, with all that stuff included, what ELSE would I need. from what I see in the search, axles are something I will need.
Would it be worth it to get the GSR ($2700) instead? I'm debating between the 2.
any help would be great. Any other things I will need other then what they supply with the swap. thanks
//Jesse
Old Nov 4, 2002 | 10:41 AM
Jonathan_ED3's Avatar
Default Re: Osaka H22a Engine (ransack)
after the initial purchase of the engine, you're going to need to have ~$1,000 to $2,000 to get EVERYTHING else and get it right. Although you could do it a lot cheaper if you really tried.
It's well worth it though...IMHO.
Especially over a GSR (stock for stock)
Axles- $300-$500
Mounts-$300-$500 depending on kit
So for about the price of a GSR, you can have all the parts to PUT the motor in. Then you can worry about replacement parts on the engine...which you'd (most would) do on the GSR too.
Don't forget suspension and brake upgrades!
BTW, I've heard that Osaka Motors does not include the shifter assembly and shift cables....something you really need if it's going into a Civic/Integra etc. You'd want to look into that before you order.
Old Nov 4, 2002 | 03:39 PM
ransack's Avatar
Default Re: Osaka H22a Engine (hot_EG)
osaka said that it came with mounts, but for an h22a I probably have to get better ones. The suspension is half way to ready for any engine swap. I need to get higher spring rate springs. and I think my konis will do just fine with it. brakes, would be more of an investment. thanks for the info
Old Nov 4, 2002 | 06:02 PM
DX187VTEC's Avatar
Dont forget the $20 bucks here and there at your local Kragen for hose clamps, electrical tape, wire, oil, antifreeze, and blah blah blah........that was the hardest part on my swap.......
Old Nov 4, 2002 | 06:49 PM
hondaZvic's Avatar
Default Re: Osaka H22a Engine (DX187VTEC)
yah.. and u can use that same 20 on some more bolts, hoses, clips, and all the other lil shiet.. that if u order at honda, they never have it and u have to wait 3+ days to get this small lil stuff.... but uh.. h22 sounds good to me
Old Nov 4, 2002 | 07:36 PM
ransack's Avatar
thats true...
heres the h22a
http://www.osakajdmmotors.com/engines/h22_97.html
they list everything it comes with
Old Nov 4, 2002 | 07:56 PM
Qfactor's Avatar
I think 1850 is for canadian dollars not the same as US dollars.
Old Nov 4, 2002 | 08:10 PM
AB16A2T's Avatar
Default Re: Osaka H22a Engine (Qfactor)
If you look at the site it says USD. United States Dollars.
Old Nov 4, 2002 | 08:44 PM
heh, It comes with mounts....Stock Prelude mounts, which are of no use to you.
So it's not a matter of getting better/new mounts or anything of that sort, it's a matter of getting a mount KIT HCP and Hasport both make great kits.
Same with the axles..the ones that come with it are of no use whatsoever to you.
Old Nov 4, 2002 | 10:59 PM
ransack's Avatar
does all that go the same for the GS-R
Old Nov 6, 2002 | 08:13 AM
EK22Tim's Avatar
HOLY COW is THAT the truth. haha!
Old Nov 7, 2002 | 04:49 PM
DX187VTEC's Avatar
Default Re: Osaka H22a Engine (EK22Tim)
truth.....
Old Nov 7, 2002 | 05:17 PM
Happyman's Avatar
yes, enless you have an integra(for b18c1) or a prelude(for h22a) the stock mounts and axels will not fit
Old Nov 7, 2002 | 05:44 PM
get wet racing's Avatar
Default Re: Osaka H22a Engine (Happyman)
Yo dude I wouldn't recomend Osaka, I went there and they screwed my friend and I, the engines arn't very good they've been sitting in junkyards for along time and aren't maintained, go somewhere else if I were you. later
Old Nov 7, 2002 | 08:22 PM
AB16A2T's Avatar
Default Re: Osaka H22a Engine (get wet racing)
Let's see here, your 5th post, and ALL OF THEM ABOUT HOW BAD OSAKA IS! For all we know you might have some vendeta against them or something, but start doing some more helpful posts, that might help us believe your story, before you start badmouthing people.
Old Nov 10, 2002 | 04:43 PM
osakajdmmotors's Avatar
"Yo dude I wouldn't recomend Osaka, I went there and they screwed my friend and I, the engines arn't very good they've been sitting in junkyards for along time and aren't maintained, go somewhere else if I were you. later"
Sitting in Junk Yards....????? Do you have any idea of where we even get them in Japan? and how would anyone on this planet know that they are not maintained with out going through every one of our motors??? If you can answer that, you are from a higher place then earth.
[Modified by Osakamotor, 1:44 AM 11/11/2002]
Baddawg1991
Nov 3, 2009 07:38 PM
mightymikek83
Jun 15, 2005 01:59 PM
christian99
Jul 17, 2003 09:45 AM
explosive
Jul 13, 2003 05:20 PM
