Skunk 2 ECU?
Old Oct 27, 2002 | 11:33 AM
JDM Civic Hatch's Avatar
Default Skunk 2 ECU?
I have a 93 Civic Hatch with a JDM B16 gen 2. I hear that the Skunk 2 ECU is really nice i just wanted to see if anyone has it and what they say about it. Good or Bad? Thanks for the help!
[Modified by JDM Civic Hatch, 8:35 PM 10/27/2002]
Old Oct 27, 2002 | 05:06 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Skunk 2 ECU? (JDM Civic Hatch)
You got PM
Old Oct 27, 2002 | 06:50 PM
Chugger's Avatar
Default Re: Skunk 2 ECU? (B18C-EJ1)
runs strong very strong but also runs rich very rich
Old Oct 27, 2002 | 08:08 PM
-Darren-'s Avatar
Default Re: Skunk 2 ECU? (Chugger)
i heard that you need a v-afc for it.
Old Oct 27, 2002 | 10:56 PM
Jonathan_ED3's Avatar
does it kill your gas mileage?
Old Oct 28, 2002 | 05:40 AM
rolow's Avatar
Default Re: Skunk 2 ECU? (hot_EG)
Yes and it goes to 10,000rpm
Old Oct 28, 2002 | 06:47 AM
HRILSVTEC's Avatar
As long as u use a v-afc with it and get it tuned it will run great. Big improvement.
Old Oct 28, 2002 | 08:00 AM
Deomonte21's Avatar
Default Re: Skunk 2 ECU? (HRILSVTEC)
I have a P28 skunk 2 chip for my GSR swap and yea the gas mileage is noticably different but feels like it pulls much harder.I would recomend also getting the Skunk 2 manifold.That also will give you a big jump in power.
Old Oct 28, 2002 | 02:07 PM
Zatar69's Avatar
Default Re: Skunk 2 ECU? (Deomonte21)
I have the chip for my GSR (in a p28) and it does pull pretty damn good. I threw in a CTR intake cam and it got a bit better!
Oh, and I'm selling the chip on ebay right now if anyone cares:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...tem=1782273419
Old Oct 28, 2002 | 04:59 PM
Default skunk ecu
I was wondering what it will raise my redline to? I heard 8,500 not 10,000. thanks
Old Oct 28, 2002 | 06:33 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: skunk ecu (JDM Civic Hatch)
There are some guys like myself that don't recommend raising your redline unless your valvetrane, and bottom end can handle it.
If you want a skunk2 chip, I can modify it for you to keep the factory redline, and I can also change the VTEC x-over point to your liking.
PM me if you're interested.
Old Oct 29, 2002 | 09:16 AM
Shft@9GSR's Avatar
Default Re: skunk ecu (B18C-EJ1)
Does this program utilize all sensors?
for example...does the computer always run open loop? does it still take knock sensor readings to retard timing?
I have this program and was wondering these things. Also...the redline is set to 9500. (p72)
I have a fully built motor and love the program. It really pulls hard through the midrange and top end. ITR cams, stock ported intake manifold, TB, JG valvetrain and P&P'd head. Bottom consists of Eagle Rods and 85mm JE 11:1's.
After reading everyone's posts, I definately need a fuel controller.
Old Oct 29, 2002 | 09:32 AM
rolow's Avatar
I was wondering what it will raise my redline to? I heard 8,500 not 10,000. thanks <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/h-emblem1.gif" BORDER="0">
I have a Skunk2 copy!
Just to clear that up its not a real Skunk2
Mine does red line at 10,000rpm
Old Oct 29, 2002 | 09:40 AM
WAFFLES's Avatar
Default Re: skunk ecu (rolow)
VTEC and Rev limits can be changed by pretty much any Chipper. It's the fuel and ignition maps that are modified that make the most difference. I have a mugen program currently with a custom 8k rev limit on it, which is supposed to be 9k if it was like the real mugen program.
Old Oct 29, 2002 | 10:24 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: skunk ecu (Shft@9GSR)
No, the Skunk2 program is a modified Mugen proggy. No Knock sensor, but it does look at the 02 sensor.
Also, Skunk2 does NOT make a chip for the LS or GSR specifically. The Skunk2 chip was designed for the P30 ECU, not the P72
Old Oct 29, 2002 | 04:52 PM
My revlimiter is at 7 grand and i hear that the stock motor can handle at least up to 8,500. Fact or Fiction? Would it be safe runing it up to 8,500 cause i know honda motors can take a beatin but not sure about 8,500 RPM. I am runnin mobil synthetic oil i think that makes a diference. thanks
Old Oct 29, 2002 | 05:38 PM
B18C-EJ1
Guest
Posts: n/a
Your stock what? LS engine? I wouldn't rev it to 8500 unless you want to rebuild it.
Old Oct 29, 2002 | 06:02 PM
No, its a second gen b16.
Old Oct 29, 2002 | 06:24 PM
B18C-EJ1
Guest
Posts: n/a
Was it an automatic? I'm trying to figure out where you got 7k rpm.
Old Oct 30, 2002 | 02:15 PM
I am thinking that it has somthing to do with the ecu its a p28
Old Oct 30, 2002 | 02:19 PM
it was a automatic motor but now its five speed that shouldn't matter?now it has a gsr tranny...
Old Oct 30, 2002 | 03:57 PM
B18C-EJ1
Guest
Posts: n/a
Yea, it matters. First off the auto b16 had crappy valve springs, so unless you've changed them, don't trust it.
Also, if you are using a P28 auto, and you have not converted to manual, that will affect the performance too.
93b16CivicSi
Jul 30, 2005 05:51 PM
bluesaint
Feb 27, 2003 12:16 PM
fred92htch
Dec 5, 2002 10:35 AM
COREY ITR#625
Oct 20, 2002 10:40 AM
Nata$
Jul 29, 2002 10:49 AM
