*** CAMS for LS/VTEC???? ***
what are the best cams for an ls/vtec??? i was thinking about the hondasaver cams or skunk2 cams....... but i dont want to tach the motor past 8k rpm or so.......its a93 b18a block with a b16 head with p&p, bronze valve guides and soem other stuff..... would these cams be good for this rpm range?? or should i go with CTR cams?? i am planning on going with new valves, springs, and retainers...... what would everyone recommend?? ohh yah and what pistons would be good also???
thanks!!!
thanks!!!
Re: *** CAMS for LS/VTEC???? *** (boostinb18)
I am using '01 ITR cams, outer v. springs, and Portflow ti retainers and inner v. springs. Good so far. I have taken it to 8k several times and even past on accident.
As far as pistons go, everybody is going to say something different. Personally I am using JE's.
Re: *** CAMS for LS/VTEC???? *** (Jeff C)
yah its going to be all motor....... i wnated to go with at least the skunk stage 2's and i was thinking about the hondasavers but will they be god for the ls/vtec??? since i dont want to tach to 9000 rpm??? will there still be a lot of power at like 7500-8000???
thanks
thanks
If you're not going to rev that high, I'd say Type R cams like someone mentioned, Skunk Stage 1, or Toda Spec A. All would give you a good bump in power once tuned and you don't have to take the motor to high RPM to make all your power.
Valve train upgrade is minimal as well.
Re: *** CAMS for LS/VTEC???? *** (ill phil)
yah i saw a comparison between the jun 3's, todas(didnt specify but i thik it was the c's) and ITR cams and the funny thing was that the r cams were only a few hp lower then the rest but had the best mid range power! i tihk it was only like 6 hp differnece! and im gonna go CTR which are a liitle more aggressive so probably a little better even!
what valve train should i go with using the ctr cams??
thanks
geoff
thanks
geoff
I have heard that the '01 itr and ctr have the same intake cam and yes the exhaust cam is the same amongst the itr and ctr.
