LOOK HERE i need help easy stuff for experts
Old Oct 28, 2002 | 08:16 PM
jl2teg's Avatar
Default LOOK HERE i need help easy stuff for experts
ok guys im a turbo integra owner but what im lookin for is some help on my girlfriends car she has a 92 4door civic lx Ive added a suspension kit a wings west bumper and some 17's but that moter is a dogg so i was wanting to swap it I orignally planed on a f22 but Ijust recived a free D16Y8 W/ 70,xxx miles to my question is this a good swap and all i have right now is the moter (block &head) is the tranny and allthe other parts bolt on affair who has done this I need info I need details what interchanges
thank you civicgurus
Old Oct 29, 2002 | 08:33 AM
jdmitr's Avatar
Default Re: LOOK HERE i need help easy stuff for experts (jl2teg)
Yes, all the stuff will fit on that motor (tranny...). You will need to use the dist. from a 92-95 Ex, or Si, and the engine harness. Hopefully you are one of the lucky ones. If your harness on the strut tower that goes to the ECU has Vtec solenoid, and vtec pressure switch (org/white, org/blue), then you can either use the harness from the Si or Ex, or you can wire it your self with the lx harness (3 wires org/white, and org/blue, and ground). If not it is a little harder, but nothing major!
If it is strong, it will be better then the Lx (D16y8 is 127 to the flywheel).
wagooovan91
Feb 8, 2010 12:38 AM
JENNY_EG6
Jan 2, 2009 01:43 PM
zaxfire
May 16, 2002 11:53 AM
