93 si engine into a 94 cx..please respond quick!!
hi i was wondering if anybody had a step by step guide for this swap? This would be my first attempt at a swap so all info is greatly appreciated. I'm trying to switch the 93 si motor into my 94 cx and my motor into the 93 si I also have both cars to work with but need to know where i should start and if there is anything else i should get? thanks a lot
Re: 93 si engine into a 94 cx..please respond quick!! (Vp Special K)
Go to http://www.c-speedracing.com and look at a few of their tech articles, that will familiarize you a bit with the process. You need to remove a lot of stuff to pull a motor but it is easy in your scenario since you are dealing with two D series motors, and have both cars. Well, you need to swap over the motor/tranny and ECU. that is about it. And you will need to add a few wires for vtec to function on the '94 car. Also check out http://tech.hybridgarage.com/index.html and seartch around their site in the archives and stuff, very very helpful.
If you are asking about this, I am wondering how easily you will accomplish this simple task, but if you are patient and have enough time, plus help from a friend, this will be easy enough and a great way to learn a lot about your cars. Also a Cherrypicker akak motor hoist is required (sort of)... if you dont have one you can drop the swap below the car and raise the car up, the "Jersey Method" LOL, to make it all work, but I have never done it that way... heard it works just fine though.
good luck bro
[Modified by owen_the_soyboy, 12:45 PM 10/29/2002]
Why? Does your CX have a 4 wire o2, or a single wire o2? Look on the harness that is on the strut tower, and if there is a org/wht, and org/blue wire on the firewall side of the harness, then you have vtec wired to the ecu, and all you need is the SI engine harness, and ecu to wire it!
