lsvtec TRANSMISSION /lsd /axle info needed
Would appreciate some accurate info:
**will a JDM ITR LSD fit into a '90 - '93 LS 5 speed ?
**any reason to not use this tranny? the ratios look pretty close to me?
**is it possible to get a good ITR transmission ( LSD&4.7FD) for under $1500? if so, where?( no, i'm not smoking crack...yet .)
**what axles are needed to hook this up to a 1990 CRX-Si ?
thanks,
wildman
thanks,
wildman
Re: lsvtec TRANSMISSION /lsd /axle info needed (racerman50)
ok....... the tranny's gear ratios are not good for a ls/vtec.... id only use it for a turbo motor, i had a ls tranny on my b16 and it SUCKED!! next there are no cable type-r tranny's so if you want a type-r trany you will have to convert to hydro which is a pain in the ***! or get a y1 which has the same gearing as a type-r tranny ( these are expensive!)...and for axles you use either 90-93 non abs teg axles or 88-89 teg axles...... it depends.
and i dont know about the LSD fitting.
BlueShadow
01-04-2005 04:10 PM
7PSiEF9ZC
11
07-19-2003 10:20 AM
