B16a1, What should i replace before installing
Old Nov 1, 2002 | 07:41 AM
STHPERFORMANCE's Avatar
Default B16a1, What should i replace before installing
I am doing a b16a1 into my 1991 si hatch.... Here what i plan to do before installing the motor.........
- New oem honda water pump
- New oem honda oil pump
- New Timing belt
- New head gasket
- New Ctr 0.25 over pistons
- Balanced Crank,pistons and rods
- ARP rod bolts
- Clutchmaster stage 3-4 Clutch
- Clutchmaster ALum flywheel
Any other suggestions on what i might wanna replace before the install....
-Thanks
Old Nov 1, 2002 | 07:57 AM
EP3_05's Avatar
Default Re: B16a1, What should i replace before installing (OutKast)
Thermostat
Radiator hoses
Misc. hoses on intake manifold
Valve cover gasket and spark plug grommets
Oil pan gasket.
Front and rear main seals. Should be done anyway since you are rebuilding the bottom end Since you are having the bottom end apart replace the rod bearings and main bearings.
Old Nov 1, 2002 | 07:59 AM
1bad_EF's Avatar
From: On a pile of junked Acuras and Hondas, WI, usa
Sounds to me like you are on the right track. However I would consider replacing bearings (rod, main, thrust). you need to get the code on the crank, block, and rods, then go to acura to get the right clearance bearings. but, if your original bearings are good you dont have to do any of this. use plasticgage to check clearance on your orig. ones.
Old Nov 1, 2002 | 08:13 AM
Default Re: B16a1, What should i replace before installing (91civic)
how much are rod and main bearings???
laziebun
Nov 4, 2007 04:57 PM
3rdGteg
Sep 27, 2002 05:56 AM
Steve Berman
Aug 5, 2002 03:13 PM
hatchy
Apr 5, 2002 04:01 PM
AlphaKennyWun
Feb 13, 2002 04:47 PM
