Building up my itr motor before i swap, suggestions??
ok i'm going to tear down and rebuild my 97 jdm itr motor before i do my swap here's a list of what i plan to get/do before i put it in:
-have the crank, robs balanced with new balanced and lightened itr pistons
-full blueprinting
-spoon or mugen head gasket
-toda valve springs with portflow retainers
-toda spec b's
-toda cam gears
-power timing belt
-block guard
-mugen oil pan
-spoon thermostat
-water pump
-an-r header
-mugen engine mounts
-toda flywheel & exedy clutch
-some other **** i forgot
anything i'm forgetting, anything that's a waste of time? any suggestions would be appreciated. thanks guys.
-Sean
-full blueprinting
-toda spec b's
-toda cam gears
-power timing belt
-block guard
-mugen oil pan
-spoon thermostat
-water pump
-an-r header
-Sean
Unceasing Measure
Re: Building up my itr motor before i swap, suggestions?? (irunfromcops)
-full blueprinting
-toda spec b's
-toda cam gears
-power timing belt
-block guard
-mugen oil pan [waste of money]
-spoon thermostat [waste of money]
-water pump
-an-r header super huge
-mugen engine mounts [waste of money]
-Sean
Sounds like you're off to a damn good start Sean . The Mugen stuff is money in the toilet though...stock will do just fine.
-full blueprinting
-toda spec b's
-toda cam gears
-power timing belt
-block guard
-water pump
-Sean
Re: Building up my itr motor before i swap, suggestions?? (Archidictus)
think an oem head gasket would be ok with the compression and high revs? i want to make this thing bullet proof before i make it real fast. don't want to have anything to worry about while i'm revving the **** out of it. thanks for your suggestions so far
-Sean
-Sean
Well an oem head gasket should lower compression so go with the mugan/spoon, and other than that like said above ditch the useless mugan stuff too much $$$ and not as many gains
[Modified by twitchm80, 6:09 AM 10/31/2002]
Re: Building up my itr motor before i swap, suggestions?? (Jackson)
How do you consider a mugen oil pan a waste of money? Are you retarded or do just only drive in a straight line?
so i would NOT reccomend it for road racing.
wait...maybe thats the moroso pan...
**** i think its the moroso pan...
[Modified by KAMiN, 11:09 PM 10/30/2002]
Re: Building up my itr motor before i swap, suggestions?? (KAMiN)
Not the mugen pan. Its just a stock pan with baffles. If anything, it will keep the motor lubricated in turns.
how about a new oil pump gear like a pro drive or a toda? good insurance or a waste of money? like i said i want to build a fast but bullet proof engine
yea the moroso is the one that's bad for cornering not the mugen.
-Sean
-Sean
-Sean
-Sean
edit : I had the toda cam gears on my old Si...they're nice as hell good choice
[Modified by Prod, 9:42 PM 10/31/2002]
ok so it looks like i may forget about the mugen engine mounts, heres the rest of the **** i forgot or added as a result of your suggestions. thanks again guys.
-new main bearings/seals
-AEBS head studs and main bolts
-Hondata intake manifold gasket
-Denso iridium spark plugs
-eventually a full length Fluidyne
and whoever said something about the seats and harnesses, i already have Corbeau Carreras and i'm getting some SRR harnesses to keep me strapped in there
-Sean
-Sean
Everything seems good but with the money you are spending you should at least get some forged pistons. If you want to keep the ITR's stock compression you can go for Probe industry pistons. Or get 11.5:1 compression pistons from je, wiseco, arias, and etc. Don't forget new axles, with that much power I'm sure you will break your axles real soon.
Do the block guards help?
Have fun with your build up it should be a blast when its done.
Re: Building up my itr motor before i swap, suggestions?? (Maximus)
I recommend Honda Saver US4 cams. Beat out JUN III's by 5 whp and 5 ft/lbs of torque. $150 cheaper too.
-Nick-
-Nick-
Forged pistons is precisely one of those things that while it may be much stronger than the factory piece, will not last as long. They are softer and will wear out faster.
Is there really a point to aftermarket rods/ pistons on an N/A setup?
Re: Building up my itr motor before i swap, suggestions?? (Lsos)
Do you have evidence or a test showing that aftermarket forged pistons don't last longer than stock parts? The forged pistons are made of a higher material and also forged at the same time. The quality over the cast alumnium stock pistons is night and day. can you run 20 lbs of boost on stock rods and pistons?
Can you run 20 lbs of boost on stock rods and pistons?
I'd also like to know your reasoning on stock pistons being better than forged.
And why are stock the only way to go on a N/A setup? What do you use to raise the CR then?
Tell us why stock are better than forged...
Re: Building up my itr motor before i swap, suggestions?? (Revolveu2)
IMO stock parts are better than forged, in an N/A setup, because:
They expand less, allowing to run tighter clearances.
They are harder, resulting in less wear.
They are cheaper (I think).
These are all good things which need to be sacrificed when running high boost, as forged pistons are in fact stronger than stock. Hiwever, if you're running an N/A setup, I consider forged pistons a bad design choice.
To raise CR, you swap pistons from cars like the CTR.
but thats not always possible with cars other than hondas. (VW's etc) Honda was just smart when making there motors, almost everything is interchangeable
Re: Building up my itr motor before i swap, suggestions?? (C5_ALLMOTOR)
If forged pistons can run at 20lbs of boost, don't you think they can run 12.1:1 compression at 9000rpm? Ask about forged vs. cast pistons in the tech forum and see what people have to say. I bet they will lean more towards forged than cast.
