b16 swap problems, HELP!!
Old Nov 1, 2002 | 01:47 PM
1tyme's Avatar
Default b16 swap problems, HELP!!
just dropped in a 1st gen b16 in to my 92 hb. i change the distributer and wired it all up. it starts up, but it doesn't idle. it just revs to 3-3.5 and keeps bouncing like it hitting rev limiter. check engine code is 1 blink o2 senser right? fixed that but still revs like crazy when i start it up. is it cuz i'm running an ls ecu? i was told that i could run an ls ecu and vafc controller for my b16 swap. my vafc isn't hooked up yet i just wanted to see if she'd fire up. it starts but have that idling/revving problem. any advice?? is it just the ecu?? should i hook up the vafc??
Old Nov 1, 2002 | 02:39 PM
976's Avatar
976
New User
Default Re: b16 swap problems, HELP!! (1tyme)
IAC valve in throttle body.
Not enough coolent - most likey since you just did the swap. I would recommend honda type 2 coolent.
Easy fix.
Let me know how it turns out
Old Nov 1, 2002 | 09:47 PM
respectblades's Avatar
try adding engine coolant first..
i had a similar problem...
then look at the codes and see whats flashing
look in the service manual and check your sensors
might be a tps sensor also
Old Nov 2, 2002 | 03:45 PM
1tyme's Avatar
Default Re: b16 swap problems, HELP!! (w00t!)
is that the valve thingy right under the throttle body? damn it! hahaha i took that thing off. i thought i wouldn't need it. thanks i'll go put it on and see what happens.
Old Nov 2, 2002 | 07:48 PM
976's Avatar
976
New User
Glad to help. I wouldn't recommend taking **** off your engine unless your sure you don't need it.
Honda_San
Aug 27, 2009 08:40 AM
WolfGod
Feb 7, 2007 01:57 PM
ricodemus
May 10, 2002 10:40 PM
gatesrex91
Mar 28, 2002 09:53 PM
