sohc vtec turbo vs. b16????
which would be better for freeway runs. i have a decision on both and can't decide which way to go. sohc would be boosting 7-9 lbs. b16 would have i/h/e.
Re: sohc vtec turbo vs. b16???? (1tyme)
B16 is basically stock is designed to produce 160hp.
SOHC turbo will be in the same area but is only build to handle 120hp. Will probably have a little more torque.
I think SOHC will break first before the b16 both daily driven in the same manner for a given amount of time.
Re: sohc vtec turbo vs. b16???? (JD_B18CDX)
I agree the sohc would be better but would fail after a while. The sohc can only hold 50hp over stock due to weak rods and you would add 60-90hp
NerveAgent
10
02-28-2005 10:07 AM
