Help!! my gsr is jerking at low rpms
For about a month now at low rpms and almost no throttle the car starts to jerk untell I give it gas. This problem really sucks because I look like a non driving *** in parking lots. Does not change over any speed. Only thing that makes it go away is more throttle.
Please help me!!!!!!!!
Re: Help!! my gsr is jerking at low rpms (h22akrd)
sounds like a fuel problem maybe a fuel pump or clogged fuel filter, also could be ignition ie: dist. cap rotor plugs or wires, check those probobly an easy fix
Re: Help!! my gsr is jerking at low rpms (cstgrd)
ok I driving home from work and it starts jerking again. So I push in the clutch and slowly start to bluid rpms. And at about 3 grand the tach takes back off to 1 grand with no change in throttle. After I would pass 3 grand the problem went away.
mine does the same thing, its pissing me of, anyone ever had this problem and fix it?
[Modified by Civ-JDM, 3:49 AM 11/8/2002]
JUN.
04-06-2008 09:31 AM
TiMiD703
05-15-2007 08:59 AM
b18bEG
11-12-2002 08:28 AM
