top 10 ways to lighten your car
im have just spent all of my money dropping in my b18c and still am not hitting 13's like i really want to, its an ek hatch back and i want to find out any way to make it lighter so i can get better times becasue i cannot afford anything else but i want to retain my ac and power steering unless that really does make a big diffrence are there alot of other ways to get my ek hatch any lighter?
Re: top 10 ways to lighten your car (ekhatchhybrid)
Here are a few....
Take out as much of the interior as possible
Lighter wheels
Carbon Fiber Hood
Take out Cruise control
Aftermarket header
Remove Sound deadening on floor
Take out Front and Rear bumper reinforcments ( i DO NOT think its a good idea, but most of the guys i know take them out)
Those will save weight, they all worked on my Ek Si...which is a pig.
I did this and ALOT more to my h/b....but its weekend and race only.
LATER
Lighter wheels
Carbon Fiber Hood
Aftermarket header
LATER
Re: top 10 ways to lighten your car (TodaCivic)
good pointers
Also, I'd recommend getting an aftermarket steering wheel and getting a lighter seat, with a 4 point seat harness (and remove stock seat belts).
Alot of the above mentioned will do it too.
good pointers.
good pointers.
Re: top 10 ways to lighten your car (poison)
im not sure how much the sparco big reclinable seats save you on weight but i know some seats that do. go hire a welder to weld you a bucket seat out of thin aluminum, thats a light seat! my friend has one in his corvette drag car. or i think summit racing sells abs seats for pretty cheap(i should get paid for that). thats http://www.summitracing.com i havn't been there in a while.
take all the air out of your tires, thats like 30lbs a corner
seriously though, gradually lower the air pressure in your tires each run until you find a pressure your happy with, use smaller lighter wheels, put 2 dounts on the back if you got them, take out your passenger seat if you want to go crazy. it's also amazing how many people run their cars with a full tank of gas.
i'm a pretty firm believer in running your car in the same trim that you drive it in everyday (with the exception of air pressure) but if you really want to get into 13's that should help you. posts some time slips to show what results you got.
-Sean
-Sean
Re: top 10 ways to lighten your car (AkumaY)
driver go on diet
stop eating wendy's and taco bell
make sure you take your dump before racing at the track too.
Re: top 10 ways to lighten your car (irunfromcops)
-Sean
-Sean
remove the A/C compressor, condensor and cooler
this makes the BIGGEST difference out over everything listed above.
its your choice, but it weighs a bundle eg 40 - 60 lbs
t..
Re: top 10 ways to lighten your car (tinkerbell)
-Sean
r u trying to be helpful or what?
t..
-Sean
t..
-Sean
not about saving weight but it will help him launch better
-Sean
-Sean
try to keep it topic focused...
t..
try removing everything under the dash ,heater box etc.sound deadening,if you want to get crazy start cutting,if not remove all windows replace with lexan.drive with no spair
Re: top 10 ways to lighten your car (Lost Type R)
I'm glad I weigh 135lb
Also, I agree with this 100% --
-Sean
-Sean
Take out the motor.... thas some big weight reduction there
Just curious...What does your timeslip look like now ? Could you post the break down ?
Shaving weight always helps but maybe theres another area that could be improved.
driver go on dietya exactly.
1 Post
driver go on diet
also, ppl love to upgrade to bigger brakes that slows your down 1.5 times more than dead weight.
greg
1 Post
Not in order:
1. Take out bumper supports
2. remove sound deading material
3. remove A/C and heater vents, heater core.
4. remove power steering
5. remove a/c lines, etc inside engine bay
6. smaller lighter battery(92+ honda/civic already have a pretty light battery compared to EF's)
7. of course, remove spare tires, jack , etc.
8. remove windshield wiper reservoir
9. remove rear seats.
10. cut out certain parts of the body underneath the bumpers.
remove unnecesarry bolts(there are some big ones like the tow hook bracket bolts, etc.
Re: top 10 ways to lighten your car (exospeedAMcrx)
"ekhatchhybrid" are you running slicks???? My friend has his '96 hatch with a USDM B18C1, skunk manifold, 2000 Si tranny, ACT Maxx Xtreme clutch, clutchmaster flywheel, intake, HX wheels with MT 20x14x6 slicks, and running his DC header open... He just pulled out the seats and some other little **** but on average it runs a 13.5... The other day when he ran it he managed to pull a 13.29@100... Traction must have been perfect but that's hella good for being a internally stock all motor GSR EK.
Re: top 10 ways to lighten your car (JDMspecEG6)
exospeedAMcrx, I agree **** power steering and **** A/C.... We build these bad *** clean looking motors and you can't even see them once you put them in and it makes you weigh more by like 5lbs. j/k may a little more than that. I hate that ****, it just clutters up your engine bay.. The other thing i don't like in there is the ABS ****... Oh well if you got it just rip it out.
1 Post
all i like to see is the motor and the trans. some wires here and there. no abs stuff, powersteering, a/c, charcoal canister, wiper fluid canister, etc. it so much cleaner with out those
