code 14 help!!!!!!!!!!!!!
Old Nov 4, 2002 | 04:20 AM
HybridHatchC1's Avatar
Default code 14 help!!!!!!!!!!!!!
i am throwing code 14, can anyone give me some ideas on how to fix this problem, i am running a 2001gsr in a 92 hatch dx with skunk2 IM and skunk2 ecu, i tryed what i know but had no luck i am getting frustrated
Old Nov 4, 2002 | 07:55 AM
Default Re: code 14 help!!!!!!!!!!!!! (Civ-JDM)
anyone? , i know somone can help!
Old Nov 4, 2002 | 07:56 AM
Deomonte21's Avatar
I have a friend that did the b16 swap into a crx so hopefully this helps.He had to have an idle regulator installed and he payed someone to connect it for him.I think this is the same type of problem.The only other thing I can think of is it may have something to do with your ECU.Sorry wish I could be more help but at least this gives you a direction to research...........FYI he showed me what they installed and its a small square box mounted on the top part of the firewall. good luck
Old Nov 4, 2002 | 10:29 AM
Default Re: code 14 help!!!!!!!!!!!!! (Deomonte21)
yea i am hoping i can fix this before the end of the week, this might help you guys help me, the car surges like around 1500-2000 rpms (cant really tell dont have a tach) and it also does it while i am trying to drive at a constant speed with my foot very lightly on the gas. i hate it, it almost makes the car not driveable on the street cause i either have to accelerate or keep letting off the gas and getting back on it.
Old Nov 6, 2002 | 04:44 AM
Bump, i still need help!!
Old Nov 6, 2002 | 08:31 AM
Jason kiDD's Avatar
First of all Code 14 is Air Idle Control Valve, and all this does is regulates your idle speed when the car is warming up till you get to operating temperatures in which it then drops back your idle to normal. If you are getting surging this is do to something else on the vacumn line end. I would recheck all your connections. A faulty or non-operative AICV should not cause your car to surge like you are explaining, especially after your car is fully warm.
Old Nov 6, 2002 | 10:42 AM
Default Re: code 14 help!!!!!!!!!!!!! (Jason kiDD)
yea i think i figured that code 14 out, its never going to go away as long as i have this ecu, but that surging is pissing me off
Old Nov 6, 2002 | 10:52 AM
Jason kiDD's Avatar
Again the surging maybe caused because of an improper vacumn connection... Check them all over again and listen for leaks and look for cracks.
Old Nov 6, 2002 | 11:40 AM
but the surging only happens at a certain rpm like 1000-2000 rpms, it doesnt surge while its idling, would this still be cause by a bad vacume? i think its just the ecu agian.
Old Nov 6, 2002 | 11:48 AM
Jason kiDD's Avatar
Well I guess if you were having problems with the ECU before then it probably would be wise to try another and see what is up..
Old Nov 6, 2002 | 02:43 PM
no its only surges when code 14 comes on, but it surges at like 2000rpm, i check all my vacume lines i cant figure it out.
Old Nov 15, 2002 | 04:41 AM
Clutch101's Avatar
I have a 2000 Hatch with a D16Y8 (obd2) in it. when i use the obd2 ecu, I get a code 14 and it surges @ about 2000 rpms. Now...here is the weird part. I have a obd2 to obd1 conversion harness. When i use it with my obd1 ecu, i only get a code 43 (i think that the code), no code 14!
What do you think?
Old Nov 15, 2002 | 05:29 AM
Default Re: code 14 help!!!!!!!!!!!!! (JDMwannaB)
What do you think?
i dont know i think its my ecu so i just got use to it,
Old Nov 15, 2002 | 02:06 PM
vivid02's Avatar
Default Re: code 14 help!!!!!!!!!!!!! (HybridHatchC1)
You can disconect the the iacv sensor on the back of the intake manifold and that will stop the surging for meanwhile. If you can you can try swapping it out for a known good one from a friend.
bobbyeg6
Mar 20, 2010 05:11 AM
ezazzmark
Feb 25, 2003 07:09 AM
