What drivers upper moter bracket for EK
what upper moter brackets will work on a b20 into a ek. i know that the 99-00 si will work but wonder if 94up ls/gsr bracket will also work. Please help a brother out I know that there are EKs with LS's out there who know what i need. ? Did the mount that came with the ls work(the one that goes through the timming cover) work on your Ek. I have herd that the b20 bracket will not work.
Re: What drivers upper moter bracket for EK (ef ect)
ls/gsr bracket are different than si
http://www.jspectuning.com/6gen/drside.htm
Use your stock mount and get the timing belt mount bracket off of a 99-00 si. The mount that bolts to the block.
you **HAVE** to use one off a '99-00 Si(R).
It's a 2 studded bracket on an angle where as all Integra's are straight and have 2 studs and one hold for a bolt and is totally differnt. (EK and Integra's use totally different driver's upper engine mounts)
xxstreetracer605
07-07-2011 06:19 AM
HarosGSRek
28
05-19-2009 04:32 AM
mnskateboarder
04-13-2008 05:04 AM
deviant1
03-21-2003 11:03 PM
