about to embark on obd2 b18c1 swap in eg last minute questions
first off from what i can remember hte engine harness plug in to the car harness located right infront of hte battery?
being an obd2 car does the alternator harness plug in?
my car is a 92si in canada and from the hydrid boards it is prewired for vtec. onlything i have to wire in is knock sensor?
my swap doesn't come with cat. which cat do i use to bolt up without extending or shortening exhaust?
planning on running a p28 chipped to run b18c but don't know which program to run. any suggestions?
in general anything i should look out for or words of wisdom before i join the dohc side?
thanks alot for all your help.
Re: about to embark on obd2 b18c1 swap in eg last minute questions (G-Prime)
if you have the whole obd2 swap don't worry about the alt. you will be fine. as well with the dist. and injectors. it will all plug up fine. i would get a chipped p28 from kenji. he can chip the one you have from your si. if you do that don't worry about the knock sensor, it dosen't look for one. hth
--- yes, those are the main engine harness plugs.
--- um, EG's aren't OBD2 cars, but yes the OBD2 vs OBD1 alternator plugs do differ. If you use an OBD2 integra engine harness in your EG, you won't have to worry about changing that plug or any other plugs for that matter.
-- that is correct. You can actually re-use your 92si ecu (P28), and have it reprogrammed to be sufficent enough to run a B-series engine. Kenji and I both provide this service btw.
-- hard call, usually when you get a B-series motor in, you take a trip to the muffler shop and get any exhaust system issues taken care of. Although....i think you can reuse your Si cat and it will mate up to the GSR's down pipe without length problems.
-- well, no P28 ecu can work the secondary buttterflies in your GSR's intake manifold, that's one shitty thing about P28 ecu's for GSR engines. So, the thing to do (when you can) is pick up a Skunk2 manifold (which is single butterfly). The best program for OBD1 ecu's to this day is the infamous Skunk2 or Mugen program (both the same program with 2 different names).
-- yes, don't drive like an idiot when get that B-series in there. People these days who get a swap done, swap out their ego too, for something more aggressive and assholey.....stay away from that pleeeease.
thanks to all your replys
especially katmans.
i've been reading about you and ff-squad since 98.
especially katmans.
especially katmans.
especially katmans.
do you have all the parts needed for the swap? Post what you've got;
engine
tranny
axles
shift linkages
ps pump and bracket
engine harness
alternator
ecu which is obd2............
thats bout it
can't figure out what i'm gonna do for a ecu.
tranny
axles
shift linkages
ps pump and bracket
engine harness
alternator
thats bout it
alright, only things I can add are:
- GS-R throttle cable
- GS-R upper and lower radiator hoses; and get 2 of the screw type hose clamps; 'cause the hoses will be a bit big on the Civic rad, but if you crank the clamps the will NOT leak
- '95 Del Sol VTEC a/c compressor mount bracket if you have a/c and want to keep it
Re: about to embark on obd2 b18c1 swap in eg last minute questions (Solid Alibye)
who said that "Made in Canada" has vtec wires my didn't had to custom wire everything well that is just my case....
x_doug-x
11
02-07-2013 11:27 AM
Hatch-Si-93
03-20-2005 07:21 AM
efjuice
10-28-2004 11:10 AM
