5G Wiring Problems
I'd always been told that a b18c1 is a direct bolt in for a 5G Civic. All articles, all DIYs I've been able to find agree that is the case.
Apparently not with my car. I have a 1994 Civic CX Hatch, and it is completely missing a 6 (3 in use) pin connector to match a connector on my engine harness. This connector wires the evaporative emissions and crankshaft speed fluctuation sensor.
So what's the deal? Do I need to swap out my main harness (At the moment I'm assuming that that is what will be required) or what?
If I do swap out my main harness, will it still connect properly to my ECU subharness? It is ESSENTIAL that I retain the stock Civic subharness.
1998 GSR engine and harness. Just popped into my head that the CKF sensor may have been added with OBD2, as it was on DSMs.
[Modified by qtiger, 11:41 AM 8/23/2002]
Nope. My engine harness has 4 connectors for the passenger side. The Civic has 3. In the Integra electrical manual, it is connector c104. Totally absent.
[Modified by qtiger, 2:57 AM 8/26/2002]
i'm 99.998% sure that you don't need anything in that extra plug. your assumption about CKF being obd2 is correct according to the diagram i am looking at. so if you dont' give a damn about the evap bullshit then you should be cool.
I'm pretty sure it's just there for nothing. If you look closer at the extra plug. You'll see that it's closed off. I did mine, and I saw that too, but when I went and checked on my friend GSR. It's just hanging like that, nothing connected.
Nope. My engine harness has 4 connectors for the driver's side . The Civic has 3. In the Integra electrical manual, it is connector c104. Totally absent.
I believe he's talking about the DRIVER'S SIDE harness. Not the passenger side, which is the ECU harness. So that's connector is not needed.
tasco
Oct 23, 2015 03:30 PM
White94Civic
Apr 18, 2008 10:42 AM
