Need help.....I'm in the middle of my swap
Ok here is the deal, I have a 98 civic sohc non vtec and i'm swapping in a 96 LS non vtec. Everyone has told me that I can use my stock wiring harness. Is this true? Because some of the main stuff isn't plugging up. I need answers quick. Email me at Sydag5@aol.com or IM me on here. Thanks in advance
Syd
Syd
H-T Poker champion
Re: Need help.....I'm in the middle of my swap (sydag5)
Everything should plug right in. The vtec part of the car side should not plug into the engine side wiring because it lacks vtec. Everything else should plug in. If there are plugs on the engine side that are not plugged in then you could have a prob. Its easy to overlook some clips and what not. I almost missed a couple in my swap! Hope everything works out man!
r3dp1n0y
05-16-2012 05:55 PM
