H22 in 6th gen hb?
guys I have a few dumb questions
ok so the h22 will fit w/ a/c in the 6th gen however, is it a bolt in affair?
I know that the h22 uses a cable tranny instead of the linkage like the b and d series motors. I havnt seen any hasport mount kits for the H22 6th gen so does anyone make them?
also what kind of 1/4 could you expect?
the hcp mount kit bolts right in , the other you have to hack a mount off to install, and also hcp makes the a/c bracket so you are set. high 13's slicked is obtainable depending on traction!
in a hatch you will be lighter of course, but you will have more traction in a coupe or a 4 door, i have a coupe and it pulls pretty hard, but a four door wouldn't be bad
h22 in 6g=
h22 in 6g=
