power steering in gsr eg??
what would i need to put p/s in a gsr eg? would a integ steering rack work or would i need a civic steering rack? from what car can i use the other stuff? can i use the hoses and pump, resevoir from an integ?
Re: power steering in gsr eg??
I didn’t see a definite answer that helped me so I’m just giving what I did and it’s working great for me.
The steering rack and lines are all OEM for the EG. as far as the pump goes I used a ps pump from a 95 integra gs, OBD1 btw. The hole that the pressure line attaches to the pump itself is just the right size and lines up perfectly.
some say they use a GSR pump but that’s most likely because it’s an older model with OBD1 emissions. If it worked for me eventually it will work for y’all eventually
bonbon
04-10-2004 02:19 PM
Drkaccrd
01-30-2003 02:30 PM
