valve clearance w/ ctr pistons in a gsr?
hey guys i am wondering if i put .25mm o.s. ctr pistons in my gsr will there be enough valve clearance? my head is slightly milled due to when i had a blown head gasket they machine shop told me they had to mill the head a little bit because it was slightly warped...this was almost over a year ago. also would i have to update my valvetrain just for the pistons? would i be able to use 91 octane? i have used the searc function and cant get a straight answer for these.
any help would be appreciated ,
thx
thx
Re: valve clearance w/ ctr pistons in a gsr? (knighteg)
I dont' know that much about bore and stroke, but the civic type R is a 1.6 and the GSR is 1.8....will civic type R pistions even work in there?
Location: Toronto, Canada currently residing in ATL, GA, USA
Re: valve clearance w/ ctr pistons in a gsr? (sivik2nr)
Yup they'll work not sure on clearance. I know a few ITR guys do it (I'm doing it as well). They make the compression ratio on a ITR 12.1:1 give or take a little I believe.
Re: valve clearance w/ ctr pistons in a gsr? (Apex i ITR)
but can it work in a daily driven gsr? pleeeez help me, i have an opportunity to buy some ctr pistons brand new for less then 300! i am gettin my gsr block taken to the machine shop and will get a .25 mm ooverbore for them to fit, i just need to know if there will be enough valve clearance and if i can use 91 octane?
i dont know exactly how much they milled my head, they said "just a lil bit" so thats all i can remember from them, that was about a year ago like i said so i cant really remember it to well
It will be fine. Just don't miss shift!!!!!
U might want to upgrade your valve train to ensure u never have any valve float.
Do u have stock cams???
