Flywheel/Pilot Bearing problem....help!!
Old Aug 20, 2002 | 06:14 PM
1fastVX's Avatar
Default Flywheel/Pilot Bearing problem....help!!
OK here is the problem...I am installing a new Fidanza flywheel on a B16A...when I went to tap in the pilot bearing it basically slid right in with no pressure....so when I installed the flywheel the pilot bearing will slide back and forth in the slot about an 1/8 inch....should I be worried about this???...anyone else have the same problem??....I am using the pilot bearing that came with the ACT clutch
Thanks for any info!!!
Old Aug 20, 2002 | 08:10 PM
DualKnuttz's Avatar
Banned
Default Re: Flywheel/Pilot Bearing problem....help!! (1fastVX)
When I did mine the pilot bearing was a tight fit. It shouldn't be loose like that. I also had to tap it in with a hammer.
[Modified by DualKnuttz, 5:11 AM 8/21/2002]
Old Aug 20, 2002 | 09:02 PM
Kamin's Avatar
Default Re: Flywheel/Pilot Bearing problem....help!! (DualKnuttz)
um it SHOULDNT matter too much as long as the bearing is not falling out.
as long as you can get the clutch alinged correctly you shouldnt have a problem once the tranny is on.
Old Aug 21, 2002 | 06:05 AM
BigDaddyRich's Avatar
you should NOT have a loose Pilot bearing!! The needles in it could become loose and lodged around the shaft causing much headache and grinding. you should HAVE TO tap in the bearing with an appropriate sized socket and mallet. if the bearing goes in and there is play... you definitely have the wrong bearing. Double check before you reassemble that tranny.
Old Aug 21, 2002 | 07:08 AM
1fastVX's Avatar
Default Re: Flywheel/Pilot Bearing problem....help!! (BigDaddyRich)
BigDaddyRich...I tryed fitting the old pilot bearing from the original flywheel into the new one and it does the same thing...so it looks like the flywheel is off spec a little...so I am calling them today to see what can be done...thanks for the reply!
Old Aug 22, 2002 | 05:43 PM
maybe you using the wrong flywheel for your tranny? just a guess?
Dxs
Transmission & Drivetrain
Apr 10, 2015 11:59 PM
greyEG
Jun 25, 2014 03:23 AM
rick_rabies
Jun 12, 2013 01:33 PM
Nathan007
Jun 19, 2009 06:14 PM
D16SiHatch
Apr 2, 2008 02:13 PM
