GS belts with B20B bottom end???
Re: GS belts with B20B bottom end??? (1QWKGS)
i dunno what a GS is (i'm aussie) but the B18 stuff should match to the B20...
have you tried fitting them, or is htis impractical...
HTH,
t..
HTH,
t..
Re: GS belts with B20B bottom end??? (tinkerbell)
Only if you put your GS Accessory Pulley on the B20B block.
I used the B20B Block pulley and the only one that fits is the Power steering. The A/C and the Alternator, you must use custom belts. Took me 3-4 trips to the autoparts store to find out which one it was.
