what exhaust on a H22A EG sedan ?
hey guys ... since my EG is becoming more and more of a hybrid i'll start posting some questions here .
I have a problem with my setup , I basically get no power from my H22A engine , and curently I'm working my way backwards to see what was done wrong in the setup or what else needs to be added .
Should anyone have anymore info on this setup and want to look at more details about my problems go here and send me a line too :
https://honda-tech.com/zerothread?id=258418
... basically problem right now is that I ran 15.5 with the setup which is just sad because when i race i get the jump all the time and then i just loose midend and high end .
Anywais the main question here was :
since i am now on STOCK civic exhaust , I am planing on an upgrade ASAP . Can anybody tell me what pipe diameter i should go with ?
2.25 ? 2.5 ? 2.75 ?
eventually when i get this setup up and running it will get sprayed and then a turbo should be going in by next summer .
Any sugestions ?
2.25 ? 2.5 ? 2.75 ?
Any sugestions ?
Re: what exhaust on a H22A EG sedan ? (civic.tar.gz)
2.25 ? 2.5 ? 2.75 ?
2.25 ? 2.5 ? 2.75 ?
As for your time, I would expect it to be a little more quicker. Stock Lude's can run low 15's, mid 14's with bolt ons. You should be well into the 14's. Definitely get the swap checked over once again.
Re: what exhaust on a H22A EG sedan ? (Prelude_RCR)
so should I stick with a 2.5" or a 2.75" ?
I am planing on spraying at least a 75 shot on the engine once it's running well
up to 170whp, 2 1/4-2 3/8" (55-60MM) is usually more then fine, from a well built system (mandrel bent no bottle necks)
2 1/2 (65-70MM) is good for 10-250whp on N/A motors, from a well built system
and this is where you will roughly fit.
Re: what exhaust on a H22A EG sedan ? (eg6ajk)
got it ... seems to be 2.50 ... i was gonna wait and say thanx tomorow cuz of my post limits but ah well
thx everbody again 4 the info
