yet another break swap question
Old Aug 26, 2002 | 08:59 AM
mrlegoman's Avatar
Default yet another break swap question
96 Civic Ex
I've got a set of 94 GSR brakes on the way. Is this swap going to be plug n' play?
Would it be worth the trouble to return the GSR brakes and order a set of SI brakes? Is there a size difference between the GSR and SI? I would assume the SI brakes would be a simple bolt on, correct?
Old Aug 26, 2002 | 10:46 AM
.(Lazarus).'s Avatar
Default Re: yet another break swap question (mrlegoman)
EX rotors and GSR rotors are the same size (at least EG-EX rotors are), just swap calipers to get the GSR's bigger pistons.
Old Aug 26, 2002 | 12:12 PM
mrlegoman's Avatar
Default Re: yet another break swap question (ATXhybrid)
I could do that for the front, but the EX has rear drums.
Old Aug 26, 2002 | 12:43 PM
JD_B18CDX's Avatar
I just did this 2 weeks ago.
EVERYTHING bolts right up. This means all suspension parts (including sway bars) and Brakes.
Front sway bar is a little more difficult because I had to remove the shift linkage. But it bolts right up.
I also got integra Master cylinder and Booster and proportioning valves. These bolts right up as well. For the master cylinder, you have to do some brake line bending.
Old Aug 26, 2002 | 01:35 PM
R_yd's Avatar
96 Civic Ex
just keep the gsr
Old Aug 27, 2002 | 04:22 AM
mrlegoman's Avatar
Default Re: yet another break swap question (Rspool)
Thanks for the info!!
92si_XX
Jun 25, 2011 08:01 AM
95_GSR_SEDAN
17
Dec 9, 2009 04:25 PM
twiztid_989
12
Nov 10, 2009 11:58 AM
.dave
Nov 25, 2003 06:34 AM
hybrid901
Feb 13, 2003 01:12 PM
