b20b idle problem
anyone have this notorious idle fluctuation on ur b20b
my setup is b20b in 92 dx hatch.. I check the iav and fast iac they are ok.. bleed the coolent..adjusted the idle.. it seems to idle fine most of the time but it fluctuates here and there and sometimes stalls... especially after warming up.. and I sometims get a check engine code 43...
anyone with any ideas??
tps sensor?
no, check your tps reports. i hear you've been havin problems with those. i'll make sure you get another copy of that memo.
im sorry, i had to.
im sorry, i had to.
I've just change the fuel filter.. i've checked for leaks but I'll check agian just in case..could the purg evap cause the problem??
