Wire harness differences
Old Aug 14, 2002 | 09:00 PM
ScottFern's Avatar
Default Wire harness differences
I need to find out the differences from the 1999 Si wiring harness, and the 97 gs-r harness, because I did a b16a2 swap into my 93 ex, and used the 97 gs-r harness, cuz it fits the plugs on the motor, while fitting the stock chassis plugs on the car....I am starting to think this was a mistake. My idle is over 1300RPM, and i get check engine lights for Intake Air Temperature, and Code 23, knock sensor, but I can figure that one out.... Anyone, have any input if this is possible for this harness and motor to work together, or am I screwed? Let me know
Old Aug 14, 2002 | 09:48 PM
00WhiteEKy's Avatar
Default Re: Wire harness differences (ScottFern)
i used a gsr harness in my 92 vx. but then again i have a gsr motor. but i moved a20 to a17. and ran the knock sensor, and I had to mess with the IAB becasue i was using a obd-2 motor and harness, and an obd-1 ecu. so i had to cut the black wire on the IAB and give that a 12V switched sorce. which means you give the black wire on the plug going into the IAB a switched sorce, not the black wire going to a ground. and mostly any yellow/blk wire is a 12v source. I hope this helps. go to http://tech.hybridgarage.com/tech/index.html They have A LOT of help on there for you. like pin locations and such.
Old Aug 15, 2002 | 11:19 PM
ScottFern's Avatar
Default Re: Wire harness differences (92hatchy)
Yea, I am using a P30 ecu for the b16a2 motor, and I am curious if the pins are different on the ecu for certain things...what exactly is the IAB...and what does it do? and I probably have that wire on my harness, but I am sure it doesn't serve a purpose cuz its a different motor. Maybe I need it wired, but what could be possible wire mismatches...with the harness and ECU....? There has to be some..
Old Aug 16, 2002 | 12:21 PM
00WhiteEKy's Avatar
check out that web site. yes, the pins you have will work. the IAB is on gsr motors. its a black box under the intake, it opens the seconrady runners, but don't worry about that. you have a b16a2 motor. if you had a gsr motor in your hatch, I could help, but im not too fimillar with the setup you have. so inother words, do some research and don't listen to me.
importracer0008
Sep 28, 2008 12:38 PM
backagainracer
Dec 24, 2006 03:59 PM
dthug
Aug 2, 2006 11:47 AM
EG civic
May 29, 2006 08:15 PM
