Any strut bar fit HPC H22 EGs? and question about the swa...?
I've heard most of them won't clear.
Does anybody have with their H22 swap using HCP Mounts?
I want to go ahead and buy one...but I don't want to buy it, and then have to chunk it when the h22 arrives Should I give up?
Also, I haven't thought about this until recently...
When using the HCP kit (or any kit i guess), Do I have to chunk the stock lower crossmember since the prelude engine sits lower? Or is it designed around it?
Re: Any strut bar fit HPC H22 EGs? and question about the swa...? (hot_EG)
Yes, any strut bar fits.... dunno about Neuspeed but on an EK, it clears (a little tight to take the oil cap off though with the Neuspeed bar). I'm running a strut bar on my EG and it clears easily. As for the lower rear crossmember, no modification is needed.
Re: Any strut bar fit HPC H22 EGs? and question about the swa...? (Newman)
Also, about the crossmember...you said lower rear...
Are we talking about the same piece? I'm speaking (trying to anyway) of the front crossmember....There is only one under the engine that I know of.
Is this what you're speaking of?
I'm using an old GREX strut bar. Lots of clearance.
EG's and EK's only have a rear lower crossmember - they don't have any front crossmembers. The front crossmember that you're talking about (stock-wise) are only found in EFs, DA Integras, and in Preludes & Accords, where the front mount bolts up to the crossmember front bracket. Are you talking about the front crossbar that HCP has for their H22 mount kits?
Maybe I'm confused.
I'm not talking about the HCP front crossbar...I'm thinking of a 'stock' crossbar.
I recently looked underneath my EG, and did not see any crossbar of any kind. Just all engine pan/transmission.
There is supposed to be supposed to be something (bar...brace...don't know the proper name) that supports the car from left to right when looking at the bottom, correct? I figured my car was just missing it because i noticed two sets of bolt holes on each subframe, but with no bar going from subframe to the other side.....I figured I was just missing something.
Are you saying there is no lower crossmember at all underneath the front end of EG's/Ek's? If so, big news flash to me
I thought ALLLLLL cars had one! It wouldn't seem to me to be too sturdy without one
Re: Any strut bar fit HPC H22 EGs? and question about the swa...? (Freakn8)
yup thats rite.. u look under a civic and all u should see is oil pan, no bar.
then on my car, my strut bar fit, but it hit the external coil... i had to twist the strut bar back... looks funny.. but it works for now....
Johnny_9
08-08-2012 03:35 AM
