h22 knock sensor ??
Old Aug 20, 2002 | 09:18 AM
billk2k's Avatar
Default h22 knock sensor ??
I have a JDM h22a in my 95 accord ex and I was wondering if the knock sensor actually needs to be hooked up in order for the car to run. The knock sensor on the car right now is crack and I am having a replacement sent to me. I just wanted to know if I could drive the car without the sensor being hooked up and if it would harm the engine for the week that there isnt one in there. Thanks!
Old Aug 20, 2002 | 09:55 AM
Mikey3000's Avatar
Default Re: h22 knock sensor ?? (billk2k)
yeah you can drive it w/o the knock sensor. just be sure you have the tune on it so at high rpm it won't detonate and blow......there will be nothing to turn back timing. if it's stock just make sure you got ignition timing at stock and fuel pressure at stock and you'll be all good.
Old Aug 20, 2002 | 11:59 AM
MPower332TI's Avatar
Default Re: h22 knock sensor ?? (Salvatore Leone)
vtec wont activate wothout the knock sensor because it throws a check engine light...but u can still drive it..just dont beat on it
Old Aug 20, 2002 | 04:20 PM
Mikey3000's Avatar
Default Re: h22 knock sensor ?? (jDmDxTuRd)
wrong. VTEC will work w/o knock sensor.
ebrakeracin4
Nov 25, 2004 09:19 AM
ace_cr
Sep 28, 2004 12:46 AM
untitledsn41
Jul 30, 2004 04:48 AM
McFly
Aug 11, 2002 02:39 PM
