crank angle sensor (CEL 4) 00' b16a2 in a 96' EX
hey you swap gurus, im having a CEL code 4 (crank angle sensor). I've double checked the wires when i repinned the 96 ex harness to work with the SI ecu. I've checked that the wires were color matched from the sensor to the plug and then to the ecu. I even toned the wires just to make sure i've pinned them up right. Does anyone have a helms manual for the 00' si that could tell me where the wires go from the crank angle sensor to the ecu plug (blue/orange and white/red)? any help would be greatly appreciated. We are done with the swap and this is the only check engine light, but unfortunatly its a critical one and the motor wont idle...im sure you can imagine. Thanks!
[Modified by djmatix, 1:43 AM 8/26/2002]
jdmdreamz414
07-22-2011 06:08 AM
