Engine mounting question.....
Old Dec 27, 2002 | 09:17 AM
Scorch7's Avatar
Default Engine mounting question.....
I'm swapping a b18A1 engine into a '92 civic hatch. Will the '93 integra mounts that match the original engine be the best way to go, or is there a better way to do this? I also hear I'll need the rear mount bracket and the bracket under the timing cover as well. FWIW, I have a '95 GSR hydraulic tranny already. Thanks for all replies!
Old Dec 27, 2002 | 10:05 AM
1bad-eg's Avatar
Default Re: Engine mounting question..... (Scorch7)
You can use the civic's original lower tranny mount and bracket, you'll need a 94up or 92-95 si driver's side aluminum mount, the 94up integ rear bracket and the 94up lower right a/c bracket and mount. You can also use the original tranny upper mount from the civic. Hope this helps.
Old Dec 27, 2002 | 02:30 PM
VTECVillain's Avatar
Default Re: Engine mounting question..... (1bad-eg)
You'll need the driver's side mount and mount bracket and the rear mount bracket for a 94+ Integra. The 90-93 B18A driver's side mount bracket is different - they are used in the 88-91 chassis with a mount kit on B motors. Hopefully you are using a hydro B tranny. If so you'll need the 94+ Integra left and right lower front mount brackets. The rubber Civic mounts can be reused with them.
blueintegra90
Jun 11, 2004 04:03 PM
Dyzee
Mar 16, 2004 12:02 PM
delacampos
Jan 27, 2003 06:22 AM
vhd
Nov 10, 2001 01:07 AM
vhd
Nov 9, 2001 05:10 AM
