Will these axles work? HELP ASAP!
I got a jdm b16a sir II that im putting in my 93cx, and i picked up some 99 civc si axles, will these work with my setup???? thanx
Re: Will these axles work? HELP ASAP! (Gray EG)
They are the same as Integra axles. The passenger side will definitely work and the driver's side should if you have the correct intermediate shaft.
They should work then. You said you have them so why not test fit it to the intermediate shaft?
[Modified by VTECVillain, 9:56 AM 12/30/2002]
