Anything wrong with this LS/Vtec setup?
Old Jan 2, 2003 | 11:29 AM
Calavera's Avatar
Default Anything wrong with this LS/Vtec setup?
BLOCK : RS Darton sleeves
Eagle Rods
JE 11:1 compression 85mm
LS knifed edge Crank
GSR CRANK CAP Gridle
New Bearings
New Oil Pump
ARP Head Studs
All new seals
Head: B16 Head
Port and Polished
Valves lifted .40mm
Full Race Springs
Thaitanium Retainers
Jun Type 3 cams
Type R intake Manifold with Ported T/B
ALSO INCLUDED
TYPE R Tranny
Double Diaphram pressure plate and ACT 6 puck disc
Spark Racing 8lb Billet Fly Wheel
RC 350cc injectors
P28 mugen spec ecu
Axles and Shift linkage
Wire Harness
And All the mounts
With the above setup, the installer told me I can expect 220 to the wheels. uhm...is that possible?
Is there a difference between Iron sleeved and darton sleeves?
Old Jan 2, 2003 | 01:28 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Anything wrong with this LS/Vtec setup? (Calavera)
Looks geat to me i wish i had as much money to do that. I like all motor but i will be broke if i do the true ls-vte swap like you. I belive you'll be happy. Maybe not 220whp but 195-205whp.....still good
Old Jan 2, 2003 | 03:13 PM
LODOSS's Avatar
looks like a strong frakenstein to me
Old Jan 2, 2003 | 06:29 PM
racecarpete's Avatar
Default Re: Anything wrong with this LS/Vtec setup? (LODOSS)
while you are at it, new water pump and timing belt. Also, make sure the gsr girdle is put on properly, it has to be milled.
Old Jan 2, 2003 | 08:07 PM
VTECVillain's Avatar
Default Re: Anything wrong with this LS/Vtec setup? (SilverCivic2k)
Whatever happened to slapping the VTEC head on and throwing it together??? - Joking - List looks good
Old Jan 6, 2003 | 02:34 PM
Calavera's Avatar
Default Re: Anything wrong with this LS/Vtec setup? (VTECVillain)
Realistically, can I do 13's with the setup above in an integra? or am I relying on hopes and dreams here?
Old Jan 6, 2003 | 03:18 PM
Jonathan_ED3's Avatar
Yes, you can.
Old Jan 6, 2003 | 07:59 PM
Calavera's Avatar
Default Re: Anything wrong with this LS/Vtec setup? (hot_EG)
Yes, you can.
With full interior and street tires? or are we talking serious gutting and slicks?
Okay and also.... 12's possible or just hopes and dreams? lol
Old Jan 7, 2003 | 01:31 AM
Quik Chris's Avatar
220whp seems a tad high for 11:1 CR to me, I don't think the pistons will bring out the full potential of the cams. Also, how did you come to 350cc injectors? Those seem a bit big to me. What other fuel mods are you doing to stay stoich? Seems like it will run rich to me. Also, what about a clutch? high RPM will tear up an organic/carbon clutch, it would be a good idea to get a 3-4 puck clutch, clutchmasters 'stage 4' is a really nice one imho, good grab, minimal chatter w/o a sore leg.
Just some things that I was thinkin
[Modified by Midori Shinkansen, 3:32 AM 1/7/2003]
Old Jan 7, 2003 | 03:15 PM
DLB1994's Avatar
Default Re: Anything wrong with this LS/Vtec setup? (Midori Shinkansen)
yeh ill go with atleast 12.5:1
Old Jan 7, 2003 | 05:39 PM
Calavera's Avatar
Default Re: Anything wrong with this LS/Vtec setup? (DLB1994)
Yeah I was thinking that too. But I don't think I can do 12's in an integra with this setup unless I go turbo.
Old Jan 14, 2003 | 08:42 AM
Calavera's Avatar
I need more opinions. bump
Old Jan 14, 2003 | 09:12 AM
sivik2nr's Avatar
On that option 2 FFtuning video that JUN hyperl lemon civic hatch was making 257 hp and it didn't have all that done to it.. so I say
Old Jan 14, 2003 | 09:42 AM
Calavera's Avatar
Default Re: Anything wrong with this LS/Vtec setup? (sivik2nr)
all that money and work just to be half a second faster than a type-r... hmmm... type-r's do the 1/4mile average of 14.5.
I dunno, this ls/vtec would go into an integra and I'm beginning to question if it'd be worth it.
Old Jan 14, 2003 | 08:34 PM
NirSpec1's Avatar
the list looks good but with the jun 3's you want at least 12.5:1 Cr to get full power from cams, And you should make 220 wheel, A buddy of mine just made 219whp with an 84mm ls/vtec, JE 12.5:1, stock head with rev valvetrain and skunk2 stage 2 cams. using a JG Eld header (open). tuned on hondata at IB, two weeks ago. So I would say run more CR and use hondata and nothing larger that a RC 310 injector.
Peace
Old Jan 15, 2003 | 03:34 AM
Calavera's Avatar
Default Re: Anything wrong with this LS/Vtec setup? (NirSpec1)
12.5? Is that safe with 91 octane pump gas?
Old Jan 15, 2003 | 08:00 AM
yes it is. 12.5 is about the limit with 91 octane.
ekay. jay
Southeast (Sales)
19
Aug 30, 2007 03:29 PM
Spec...G@rage
Apr 25, 2006 04:58 PM
petergriffen
Mar 15, 2006 05:37 PM
GodFather of Boost
Aug 17, 2004 08:04 AM
Sp33dStarVirus
Jun 7, 2003 11:08 AM
