leaky trans
Old Jan 2, 2003 | 01:49 PM
sihatchyvtec's Avatar
Default leaky trans
i have gsr and my hondabond is not working as well as it should on the trans.. oil is starting to leak.. is there neway i can fix this w/out taking the tranny apart to replace hondabond or thats the only way 2 do it?
Old Jan 2, 2003 | 04:32 PM
KENLUDE97's Avatar
Default Re: leaky trans (sihatchyvtec)
the only way to do it "correctly" is to take the Tranny apart. Sorry
Old Jan 2, 2003 | 05:23 PM
Nameless RB26's Avatar
Default Re: leaky trans (KENLUDE97)
No there is no way.
But next time to make sure it's sealed up nicely:
Drain fluids and make sure the inside of the case is DRY of oil. Then.. dab some paint thinner or a solution similar onto a piece of non shredding cloth and wipe off the surfaces. Wait a couple minutes, then apply the hondabond WITH putty knife. Don't put it on super thin, but don't put it on super thick.
Make sure to torque the bolts in an X pattern. 24 ft-lbs. It should come out the sides just a tiny bit.
MIGPA26
Jun 20, 2008 07:55 AM
classciv
Apr 19, 2006 04:49 AM
bossman032
Oct 9, 2003 09:24 PM
DEVIN22CBR
Apr 17, 2003 09:13 AM
LOwrestling2001
Jun 17, 2002 09:19 AM
