'92 ls Intermediate shaft work in a '95 Integra?
I checked at a-autmotiveparts.com and it says they're different part numbers. I was just trying to make sure since I have a '92 LS intermediate shaft. Will it work in a '95 Integra GSR with a ls motor and b16 tranny? Thanks for any info.
HT's Biggest Loser
Re: '92 ls Intermediate shaft work in a '95 Integra? (specie)
Re: '92 ls Intermediate shaft work in a '95 Integra? (SIXTYdashONE)
Are the lengths the same? If so, I'll go to the auto parts store tomorrow and pick one up. Thanks.
If you have a 92 LS intermediate shaft, then you need the 90-93 integra axle. If you have a 95 intermediate shaft, you need a 94-01 axle. Simple as that. As long as you have them matched up, they will work fine and they are the same length.
Re: '92 ls Intermediate shaft work in a '95 Integra? (juz1badLS)
Actually, I was going to put a '92 LS swap (replace pistons and bearings) into my '95 GSR because I found a good deal for the swap. I traded the tranny off and I'm using the wiring harness, injectors, and ecu. I just bought a '95 LS longblock so I'm stuffing that in the car now without a rebuild.
I'm going to rebuild the '92 longblock with forged pistons and swap it in when the '95 LS motor blows.
Now, if you're curious as to why I have a LS motor in a GSR shell, I bought the car w/o drivetrain and I can't afford nor want to put in a GSR swap (too much $$$).
1 Post
Re: '92 ls Intermediate shaft work in a '95 Integra? (madtownhonda)
greg
I thought that was probably the case. Well, if your LS motor comes up missing stock parts, let me know. I have lots.
ZAKU
08-01-2008 10:01 PM
EG*MonKEY
11-19-2003 05:16 PM
