Honest opinions on difference between hydro/cable tranny
Did a search, still some questions. Whats worth spending the extra 1100 dollars to get a 2nd gen b16a when all u get is basically a hydro tranny. This is no drag project just a daily cruiser with some ballz TIA
Re: Honest opinions on difference between hydro/cable tranny (GreenChromeCRX)
Hydro trannys have better/stronger internals than cable series.
There's more optional final drive kits available for hydro tranny's vs. cable trannys.
..overall hydro trannys own cable trannys.
[Modified by Katman, 2:25 AM 12/30/2002]
jdm b16a first gen (sir1).....
10.2:1 compression 158hp and 111ft lbs of tq
cable tranny, and non obd.requires a mount kit to place in a usdm chassis.
second gen b16a (sir2)
168hp and 116ft lbs of tq
hydrolic tranny, obd-1, drops rite in with no mount kit.
If your thinking of using a sir1 in a obd1 or obd2 chassis you will need the following
1)Hydrolic tranny
2)obd ecu
3)obd injectors
4)distributor
5)speed sensor on tranny
6)i've been told both ways but you also need a mount kit.....
then you also run into legality problems and the fact that you have an engine that is 10+ years old going into your car....
the second gen has better cams and head
Re: Honest opinions on difference between hydro/cable tranny (b16ahybrid)
You didnt read my question did you. I know the difference between the engines, but im talking about what a hydro tranny has over a cable. I plan on putting a 2nd gen b16 into a 91crx. I searched but i must have not used the proper wording. The other guy that replied answered my questions with that the internal parts on hydro tranny are beefier and just better designed. Thanks
You didnt read my question did you. I know the difference between the engines, but im talking about what a hydro tranny has over a cable. I plan on putting a 2nd gen b16 into a 91crx. I searched but i must have not used the proper wording. The other guy that replied answered my questions with that the internal parts on hydro tranny are beefier and just better availability to repair. Thanks
Sure your topic says difference between hydrolic and cable tranny's.. but then it changes to asking about the 1st gen and 2nd gen b16a's....make up your mind otherwise you get answers to two different question that were both posted by you.
You asked and you got
LHC
03-13-2003 04:34 AM
