B16A1 swap, but Speedo doesn't work???
New User
Well I just finished up my friends B16A1 swap and took for a test drive and found out that the speedometer doesn't. What could be wrong or what did I do wrong?
Re: B16A1 swap, but Speedo doesn't work??? (VTECVillain)
My friend had the same problem. And it was the same solution. Hmmmmm, guess that happens a lot on DIY swaps.
Re: B16A1 swap, but Speedo doesn't work??? (CivicSiR7)
well itll go down pretty deep and youll hear it kinda bottem out
if it still doenst go down pull it out and twist the thing with your finger and try again
hope this helps
also did u take out the little gold "U" pin?
hope this helps
You should have a small brass retaining clip that locks over it. There's a groove that it will clip into right above where it goes into the tranny.
hondagurl00
10-19-2011 01:13 AM
seeeya04
06-17-2005 11:31 PM
