torque specs for clutch
Re: torque specs for clutch (Kermit EK)
This is the stock torque for 96 and up Gsr. Assuming you have a swap.
6/1.0 mm 12 N-m (1.2kgf-m, 8.7 lb-ft.) drive plate.
12/1.0 mm 74 Mn (7.5kgf-m, 54 lb ft) washer, torque in a crisscross pattern.
Helms pg. 14-167
[Modified by Vertigo, 9:52 PM 12/27/2002]
Helms pg. 14-167
Re: torque specs for clutch (Vertigo)
19-20 ft lbs for the pressure plate bolts
If you use 8.7... good luck!!! If you use 54... SNAP!!!
Crisscross pattern applies here so you wont warp the clutch disk.
Pete
Pete
DragSource
05-26-2005 05:57 PM
