b20 in crx overheating
Okay I just put the motor in, let it warm up and it goes to 3/4 on the temp guage without the fan going on. Here is where I'm confused, the crx si harness has the two prong plug and a regular plug for the two thermosensors(what it's called in crx chilton's manual). On the b20, there are two regular plugs, one for the engine coolant temperature sensor and one for the ect switch(According to Integra helm's). Are these the same sensors? If so, which plug goes on thermostat cover and which goes on the head? TIA
[Modified by Brad, 2:43 PM 12/30/2002]
HT's Biggest Loser
Re: b20 in crx overheating (Brad)
i had this problem also, but if the two are crossed, u should get a code 6, which is ect, but if u switch them, it shouldnt throw a code, then it is correct.. good luck..
Re: b20 in crx overheating (FawkWomenDrivers)
sup guys, im doing the b20z/vtec swap and im using the b16a head for the vtec, anyway what timing belt can i use. i got the 99 civic si timing belt, but u think its the crv? or is it some other belt?
thanks
thanks
Re: b20 in crx overheating (B16integra)
sup guys, im doing the b20z/vtec swap and im using the b16a head for the vtec, anyway what timing belt can i use. i got the 99 civic si timing belt, but u think its the crv? or is it some other belt? thanks
[Modified by 10psi, 10:27 PM 1/1/2003]
