Is this correct?
putting a JDM b16a2 into a 94cx....
first, swap the jdm engine harness with a usdm dohc or sohc vtec harness.
second, get a p28 and reprogram to a dohc vtec specs(of my choice).
third, wire the vtec solenoid, oil pressure to the ecu, and change the 1 wire o2 sensor to 4 wire?
someone tell me if I'm on the right path or not?
just use the stock harness and modify it check out the hybrid garage website for the ecu pinouts and what u need to add and id use the ecu that goes with the engine example a gsr has p72 id use that one for b16a im not sure what one it is u can check out hondata.com for that
ben1284
Apr 5, 2008 07:05 PM
HATCHingMN
Jun 29, 2004 02:24 PM
4gvtec
10
Feb 28, 2002 06:01 PM
