cam gear q's
cam gear q's
i have all motor b16a2 with high comp pistons ,jun head package and toda cams......on the toda cam gears,,what is best advance or retard,exhaust or intake or booth
Re: cam gear q's (jdm civic 2000)
Advacing will move powerband to lower rpm.
Retarding will move power up in the rpm.
Moving one of the cams affect overlap.
More overlap is good for high revs.
Less overlap makes good torque but less top end.
We cannot give you a good advice because there is too much variables.
With the info above, go and try it on a dyno.
Maxi
11-09-2001 10:37 AM
