B16A wiring into a 90 Integra
My understanding is that pin A8 on the ECU should be blank and that all I need to do is insert a pin there. A8 on my car is used. Has anyone else run into this?
Re: B16A wiring into a 90 Integra (VTECVillain)
Does anyone know about the knock sensor wiring the B19 it has a wire in it already do we just cut it and put it there? PWO ecu, I can find what that wire does also?
Re: B16A wiring into a 90 Integra (4crx4me)
a8 is vtec.. if there is a pin in there. and you dont have the means to wire the vtec into the original harness. then cut the wire and run it direct to your vtec solenoid.. but you have to attach teh vtec pressure switch to and ground that also.
DYNO-PRO
Location: SoCal I.E 909, CA, where we innovate not immitate
Re: B16A wiring into a 90 Integra (turbohondask)
clip that wire in b19 and run that to the knock sensor. it is originally used for the ELD electronic load detector
Arthas
04-23-2012 01:30 PM
lsvtecSIrex
06-14-2006 03:13 PM
juicy.koreans.suck
12-25-2001 01:54 PM
